RemoteApp Black screen
alex@ibcos
Post by alex@ibcos » Thu Sep 06, 2018 1:59 pm
We have a site currently using 11.50.9.4. One user on site when they try and login the application, floating panel or Desktop screen goes black and we unable to close it (unless we kill it from task manager). We are able to log into the TS Plus box via standard RDP and other using we the same settings are working correctly with the RemoteApp setup.
Please come can someone help as we have other sites getting updated and installed with TS Plus and would like to know how to fix this if others start getting the same issue.
Alex T
Re: RemoteApp Black screen
Post by admin » Sun Sep 09, 2018 2:49 pm
This ongoing issue with RemoteApp occurs around the 15th session and there will be a fix very soon for this issue, the beta is being validated as we speak.
alex@ibcos
Post by alex@ibcos » Tue Sep 11, 2018 7:12 am
Thank you for the response.
Can you please reply back to this when the fix is ready and what sort of time scale are we look at here for the fix?
Alex
Post by admin » Tue Sep 11, 2018 11:39 am
The fix for Remote App is now available. you can proceed to update your TSplus server to the latest release.
alex@ibcos
Post by alex@ibcos » Tue Sep 11, 2018 2:05 pm
We have loaded the update and rebooted the server, with no luck we are still getting the same issue.
Alex
