I cant connect after installed the update kb4038788
I have problem with TSplus, I cant connect after installed the update kb4038788. Please Help me
Re: I cant connect after installed the update kb4038788
The solution is to apply the latest update release.
Please download and install this update for TSPlus : http://dl-files.com/data/UpdateRelease.exe
A reboot will be required.
You will find more detailed information about TSplus updating process here : http://www.terminalserviceplus.com/docs ... rvice-plus
