I'm trying to setup a TSPlus gateway behind a firewall.
on the firewall I have setup a NAT rule on HTTPS (443) port to enable the access from the outside.
the html5 version works great, and the remoteApp started from the browser works great too.
the problem is the generated client that seems to ignore the load balancing port and doesn't start.
this is the configuration of the client:
below the Screenshot of the error:
this is the cgi retrieved with the https port:
is this behavior correct?
may I have to open the port 80 on the firewall only to let the load balancing work?
Any help is appreciated,
thank in advance.
Davide
Problem with TSPlus Gateway on port 443
davide.villa
