A new version of TSplus has been uploaded right now and is now available.
Fixes:
- Contextual Menu: advanced parameter "filetransfer-servertopc-deletefileaftertransfer" is now properly applied
- Session Management Settings: fixed require reboot when settings have been modified
- Compatibility: fixed compatibility issues with latest Windows updates on Win 10 20H1, 20H2 and 21H1
New Release 14.70.6.3
widodobudi
Re: New Release 14.70.6.3
On every new tsplus release, after applying it and restarting the server,
most users cannot smoothly update their tsplus plugin on their browser.
Process of uninstall the previous plugin version, clearing browser's cache and install the new plugin mostly got problem on users.
Is the updated plugin not equipped with routines to uninstall previous plugin, clear browser's cache and then install the new plugin?
We always have to remote users when tsplus has new update to perform the un-installation of previous plugin, clearing cache and install the updated plugin. We have hundreds users using tsplus remote app and this remoting are not a small works.
Do you have small tool that can do uninstallation of previous plugin, clear browser's cache?
Rgds, Budi
Rgds, Budi
