Load balancing updates
johnrollins
Post by johnrollins » Mon Dec 14, 2020 11:26 am
We would like to disable one server from our farm so that we can run a Windows Update. How do we do this?
1. Is there a setting to leave the server in the Load Balancing dialog but disable it so that no new logins are sent to it? We couldn't find a setting so we removed the server. I don't like deleting entries in case we re-add them incorrectly. If there is no setting to disable a server, could you add one please?
2. After removing the server, it looks like users were still being redirected to it? Do we need to restart the web service?
3. As a side note, if we restart the web service does it kill existing sessions or can users continue where they left off.
Thanks,
John
Re: Load balancing updates
Post by admin » Sat Dec 26, 2020 9:49 am
Uncheck the "Server is enabled" box. make sure that all users have closed their sessions in the session management tool located in the admin tool / home / session manager.
You will then be able to update your server and reboot, afterward, simply re enable your server and you'll be good to go.
