It would be helpful to be able to export the Blocked and (or) White Listed IP addresses so you could import them into another server.  It would save a lot of work instead of having to manual enter each white listed IP address etc.
Thanks,
Simon
						Import/Export Blocked/White List
Re: Import/Export Blocked/White List
Hello Simon,
It is already the case. The informations regarding white list and black listed IP's are stored in database \archives\backup-YYYY-MM-DD_HH-MM-SS\data\data.db
