we have a Server with TSplus 14.10.7.6 and TSplus Advanced Security 5.0.7.13.
When we start a certain Applikation (ERP) which runs a powershell script at startup, Advanced Security Ransomeware is blocking the powershell.exe:
C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe
Also whitelisting powershell.exe does not solve the problem.
At the moment we have to disable Ransomeware Protection to run out customers ERP.
Are there any know issues with Advanced Security and powershell?
Michael
Advanced Security blocks powershell.exe
Re: Advanced Security blocks powershell.exe
Sorry for the late reply. These are known issues that are being addressed. Meanwhile I recommend you to use the previous version of TSplus Advanced Security. here is the permalink : https://dl-files.com/archives/RDS-Knigh ... curity.exe
Rename it Setup-RDS-Knight.exe before executing it.
Can you say when there will be an update/fix for this?
