How to prevent simple users to acess to others applications than published in TSPlus ?
Simple exemple:
We want to publish notepad.exe only (users will only see notepad.exe, not the full desktop)
The user connects to the html5 web interface with his user, click on "Save as" from notepad.exe, and in that window, change path to (e.g.
then scoll down to "cmd.exe"(e.g.), then right click and choose "Open".
Now, you have acess to cmd.exe (e.g.) !
How to prevent user to launch others applications than published in TSPlus ?
Thank you in advance,
Best Regards,
Alex
