Hello Everybody
I am using trial latest version of 11.60.10.19 on one of the VPS server. The TS Plus hosted on VPS from Contabo, Germany.
I am facing some issue in printing.
- While run application from browser through HTML5 then everything works fine with printing. PDF is being generated and available for printing / download.
- Problem in printing is when run the application from RemoteAPP Connection generated (.connect file). Application works fine and run properly but when print is being fired. Nothing happens and no response. But when I connect using Administrator and run the Application Universal Printer works fine. I have given complete rights to the user of application folder. Kindly advise where the PDF File is being generated on server side. It seems that I need to provide the rights to the user of that folder where the PDF being generated on Server Side.
Best Regards
Rajesh Malhotra
Printing Issue RemoteApp Client file (.comnect0
ramalhotra
