i used this manual to change the parameters of a .connect file: https://www.terminalserviceplus.com/doc ... ted-client
But when i click ok on the dialogue "would you like to verify the current settings for this workstation?" the small window with the complete parameter list does not come up.
What's wrong here?
Michael
not able to change .connect parameters
Re: not able to change .connect parameters
You need to launch your client once so that you can edit its settings afterwards.
Thanks, now i understand how this is working.
