Tested latest RDS-Knight, Brute-Force-Protect works very good.
But Country-Restricton does nothing, doesnt matter which settings are enabled etc..
Win2016, Firewall enabled.
If i allow only one Country (eg. Austria), i have a lot of Brute-Force-Attacks from Russland....
So, RDS-Knigt is useless for this?
regards
RDS-Knight Country Restriction not working
- Site Admin
- Contact:
Re: RDS-Knight Country Restriction not working
Thank you for contacting us.
Would you be able to collect RDS-Knight logs so we can have a look at your issue?
Please edit the file "RDS-Knight-Service.exe.config" located in RDS-Knight setup directory (typically "C:\Program Files (x86)\RDS-Tools\RDS-Knight") as an administrator, and replace the lines:
by:
Then, save and restart the RDS-Knight service to apply the changes.
Perform a connection which should be denied by Homeland Access Protection and send us the logs located in the following directory: "C:\Program Files (x86)\RDS-Tools\RDS-Knight\logs". Also, could you indicate the country the connexion is from?
Alternatively, we can also investigate directly on your server if your are willing to grant us an admin access.
Best regards,
Thomas Montalcino
Code: Select all
<level value="INFO" />
Code: Select all
<level value="DEBUG" />
Best regards,
Thomas Montalcino
Best regards,
Thomas Montalcino
RDS Knight and Server Genius developper
Thomas Montalcino
- Site Admin
- Contact:
I would like to add that Homeland Access Protection feature is designed to block any attempt at connecting using Remote Desktop Services from an unauthorized country. Therefore, any TCP connection which do not result in opening a user session are ignored by this feature.
Best regards,
Thomas Montalcino
Best regards,
Thomas Montalcino
Hi Thomas,
to my surprise, after restarting the RDS-Knight-Service (to enabling Debug-Log), all works as expected, all good now.
If you still need the Debug-Logs, send me a PM.
Many thanks for your Support!
it+t
it+t
