USB Foot Pedal
USB Foot Pedal
Is it possible to share a usb footpedal in the HTML5 connection? If not how can I share it in the regular TSPlus connection. In the past I have used USB redirector software, will this continue to be the case?
Re: USB Foot Pedal
Device redirection is not supported with HTML5 because it is full web content handled by browser. You will have to use a different connection method and use either a procedure for installing this device in a RDS / terminal server environment or use a USB redirector software.
Re: USB Foot Pedal
Thanks for the reply. USB redirector is what I opted for and works fine.
