I have the folllowing situation. TsPlus server with an application that can send mails with pdf's attached to a emailclient.
This works fine as long there is a emailclient on the server. .DOCX and .XLSX files can be redirected to the
local client. This works fine. Has anybody found a solution to redirect emails locally and send them from the
local machine ??
Any help appreciated.
Best regards,
Aad
TSPlus server email -> local emailclient.
Re: TSPlus server email -> local emailclient.
Sorry for the long reply. I am not to follow what you are trying to achieve here. If pdf format is an issue, why don't you zip them before emailing ?
What I mean is sending a complete email with attachment direct from the server to the local emailclient, just like you can send a .doc file or
excel file direct to Word or Excel on the users computer.
Best regards,
Aad Gouka
Best regards,
Aad Gouka
This has been on our road map for the last two years but is more difficult to achieve than expected. We hope to be able to achieve this by the end of 2018.
