New Application Panel
Hi.
Sorry for being thick, but where do I assign the new Application Panel to each user? I have found where to customize it, but haven't been able to assign it to anyone.
Cheers.
Ivan
Cheers.
Ivan
Re: New Application Panel
Just to answer my own question, the Application Panel won't show up automatically on the Assign Applications form, I had to manually add it in the Application Publishing form. The one I guessed it is can be found here: "C:\Program Files (x86)\TSplus\UserDesktop\ApplicationPanel.exe".
But I am sure you all knew that!
Thank you for your feedback, usually this application cannot be removed from the admin tool, updating TSplus should restore it thought. Glad to know you managed to sort this one out.
I have setup some users to work with the new Application Panel replacing the "old" floating panel.
this new Application Panel is very very good.
there is only a little regression:
there is no "Logoff" button in the application panel and the only way to disconnect the user is to close the panel window with the [X] button.
and there is no waring message to ask if the user want to logoff so there is a risk of closing all the opened application....
Bye.
Bye.
That's a very good point.
I'm also missing the important Logoff button like on the "old" Floating Panel.
Best regards
Jeffrey
Best regards
Jeffrey
I am glad to know you enjoy the new application panel
I had confirmation that the logoff button is on its way and should be available for the next update.
