New Release 10.50
New Release 10.50
The new release 10.50 is a major release.
- The logon process (logonsession.bin) has been changed to avoid display of a File Explorer
in some cases. It also have been audited to avoid svcr.exe crash which was still happening sometimes.
It has been enhanced to warrant better performances and shorter logon delay.
It includes now the required code to handle the new 10.50 capabilities.
- The code of installuniversalprinter.bin and removeuniversalprinter.bin has been enhance to provide a
better result, even in specific cases. However, we will add Universal Printers features in the next 10.60
release which will probably be announced before the end of 2017.
- The Client Generator and the AdminTool "Assign Application" tile has been changed to provide
a new great feature: Each user will see, in his START menu, and within his TRAY icons, the list of his
assigned applications. Without using his generated client, he will be able to select within these
"Local Menu" one of these application and to start it as a RemoteAPP.
To enable this nice new feature the Administrator must generate new connection clients.
With the AdminTool, The Administrator can also decide whether or not he want to allow this new
feature to be available for his users.
- HTML5: The file transfer by Drag/Drop has been greatly enhanced to prevent files missing and to allow transfer of large number of files. If a files name already exists, instead of replacing it, it is automatically rename. The memory size and the CPU requirements as been optimized to warrant a strong stability and
predictability of the result when a user is dropping large files or folders. Some other enhancement has been made for a better handling and display of the file transfer feature when using the Drag/Drop capability of the HTML5 client.
The design of icons of the HTML5 Mini Menu has been enhanced.
- Windows 10 Home. We added to support of Windows 10 Home. As you know this was removed
beginning of the year 2017; however it is not included as it was in 2016.
- Advanced security. For over a year we are investing to provide the best security to our customer.
To do so, we developed an new and amazingly easy-to-use and effecient new TSplus Add-on
named RDS-Knight. This new add-on is proposed with 2 possible : The Security Essential which cost
$49 and the Ultimate Protection which we propose at a discounted price of $275 (we sell it for $485 when a customer is not a TSplus customer). To know more about RDS-Knight benefits we created a nice 4 minutes video: http://rds-tools.com/rds-knight-overview.html
As result, the 10.50 AdminTool Advanced security tab have been changed.
We removed the old RDP-Defender, PC name and Working Hours features.
Re: New Release 10.50
A new version of TSplus is being uploaded right now and will be available within few minutes. This is release 10.50.10. released the 07 October 2017
- In the new release 10.50, assigning application to Groups was omitted.
It is fixed now.
We also optimized this part of code to speed up the logon process and to make
if faster.
It is fixed now.
if faster.
A new version of TSplus is now available. This is version 10.50.10.26
- Floating Panel: The AdminTool option to display minimize/close was not working
It is fixed now
- Issues when assigning applications to Groups has been reported.
According to our test it is fixed now
- RemoteAPP On Client:
The list of assigned application was empty when hte Taskbar or the Floating Panel
was not assigned.
It is fixed now
We added the capability to change the default title "My Remote Applications"
by what you want: For example "Yes We Can"
The application icons displayed in the START menu are now the icon selected
by the administrator when he generate the connection client.
We made some enhancements to make the result more predicatable and this
enable the user to be less confused.
- Universal Printer: The display name "Virtual Printer" has been changed to
Universal Printer to be consistant with the generated client or the RemoteApp
client.
For your information: In the next release "10.60" the Universal Printer will not
be display anymore as a server printer. With HTML5 and generated client
the user will just see a redirected Universal Printer.
It is fixed now
was not assigned.
It is fixed now
client.
A new version of TSplus is now available. This is version 10.50.10.31
- License issue: When a license was Unlimited, the system service was turning it to a trial license.
It is fixed now.
For all customers having this annoyance, the solution is:
1) Stop the service Application Publishing Service (APS)
2) Download and apply this Update patch
3) Use the AdminTool license tab Activate License tile
to activate the Unlimited license
4) Reboot
- License issue: Sometime no user was able to open a session when the trial
period was ended. For customer using AZUR, for example, it could create
serious issuse.
It is fixed now
- License enforcement: The license control for the number of users has been improved
- W10 Home: The problem of W10 Home has been fixed
It is fixed now.
4) Reboot
serious issuse.
It is fixed now
A new version of TSplus is now available. It is version 10.50.11.19
- HTML5
New release of Chrome Android zoom level recognition issue.
Google has changed the way the zoom recognition can be done.
After Chrome Update, it makes the recognition impossible and it brakes the proper working when using Chrome on an Android device.
It is fixed now.
New release of FireFox on Android Timeout issue.
Some customers are disabling the sound and with the new release of Firefox on Androidit stopped the required timeout features.
Some file upload popups stopped to work because the popup got focus but parent stopped to be active.
It is ficed now.
Webime program has been changed to keep the focus on the current windows when changing dimension.
A new feature has been introduction to enhance the keyboard behavior when entering on an editable field.
One new variable is added to setings.js:
W.autoKeyboardPopup = false; //When true, click in editable field calls software keyboard (by native keyboard only on second click).
When = 2 keyboard will be always called when cursor already editable!
Also possible value are:
W.autoKeyboardPopup = true;
or
W.autoKeyboardPopup = 2; = 2 it is very aggressive and calls keyboard even by intention to leave editable field.
One new feature for mobile devices:
It is now allowed to do horizontal scrolling (not only for vertical scrolling) However it is possible only on new Windows systems like Win2012.
Someother small unmentioned bug as been fixes.
For example, after updating Chrome, the PC button in File Manager to process file upload got scroll bars.
Webclientdata program has been fixed to avoid cases where the delay to analyse the device was too fast.
- HTML5
It is fixed now.
It is ficed now.
or
A new version of TSplus is available within few minutes. This version is 10.50.11.23
- Universal Printer issue fix
On some systems the Universal Printer for TSplus generated client was not working as expected.
It was difficult to identify why it was working proper on most system but not some ones.
We do beleive that it is because of some Windows updates which was changing some TSplus registry settings.
However, we have "ruggudize" the TSplus code to prevent such issueto happen again.
For any customer claiming that the Universal Printer is not working like it was before, we recommand to download this Update Release version, to apply it and to reboot.
A new version of TSplus is now available. This is version 10.50.12.1
- On Windows Home Edition some builds was not supported.
It is fixed now
- Universal Printer using the Web Portal with HTML5 was not working as expected.
It is fixed now
It is fixed now
It is fixed now
A new version of TSplus is available. This is version 10.50.12.4
When a customer was applying the Update
AND was using the Universal Printes V1 based on CutePDF, the Universal Printer was not working anymore.
It is fixed now
- New feature:
The Application Panel new feature has been added to the AdminTool.
It is one of the expected feature for the upcoming release 10.60
It is fixed now
- New feature:
