Can't use Remote Taskbar or FloatingPanel
Bebel
Post by Bebel » Thu Jun 29, 2017 12:45 pm
Each time I create a new user he always get
(9.3 KiB) Downloaded 1664 times
the "MS REmote Desktop". No way to use Floating Panel or Remote Taskbar.
What is wrong with my configuration ?
Bebel
Re: Can't use Remote Taskbar or FloatingPanel
Post by admin » Fri Jun 30, 2017 8:42 am
You cannot use the floating panel + the remote desktop + remote task bar simultaneously. You need to choose one of these three options.
If you cannot see your users and groups because your TSplus server is member of a domain, you will need to connect using a domain administrator account.
Bebel
Post by Bebel » Fri Jul 07, 2017 1:32 pm
It works, It was here:
Serveur / Préférences d'ouverture de session /Tous les utilisateurs ont un bureau complet should not be activated.
