all apps open
asqi
all apps open
Post by asqi » Thu Jun 08, 2017 10:31 am
Hello all,
when user logon,chose1 app,all apps launch !
any ideas?
Re: all apps open
Post by admin » Fri Jun 09, 2017 1:52 pm
In order to prevent the launch of all published and assigned application to a user or group, you will need to use the floating panel, remote taskbar, or application portal if you are connecting through the web portal.
More information about the floating panel and remote taskbar can be found here : http://www.terminalserviceplus.com/docs ... ting-panel
More information about the application portal can be found here : http://www.terminalserviceplus.com/docs ... ons-portal
