After updating my systems to 10.20.4.28 i randomly get a popup after login saying "Access denied. Ask your Administrator". Then the session will be logged of.
Seems to be a bug in the new realease.
A quick solutiion whould be good.
Michael
Access denied for Administrator on release 10.20.4.28
Re: Access denied for Administrator on release 10.20.4.28
Could you open an admin tool / licensing tile and click on "Current system audit" to make sure that all lights are green. If not, reapply the latest update and reboot.
iHi,
surely i checked this on every system. All lights are green and all system are on 10.20.4.28.
It never happened before, only since this update. It does not happen with the webclient.
I tried this with different Users, mainly with Domain-Admins and local Admins.
As i also mentioned in the ticket with Olivier, the error message comes from the Runtime process (32 Bit) AutoIt which starts in every user session.
I saw this in the taskbar and in the taskmanager just before the session is logged off.
This process leads to the svcr.exe in c:\wsessions.
I use WIndows Server 2012 R2 on every system.
i'm wondering what the difference is between webclient login and windows client login.
Can this be an issue with the universal printer?
