After the recent TSPLus upgrade the seamless client now logs in, opens the app, and logs out immediately.
Prior to this it worked fine.
Remote desktop and remote app work fine.
Thoughts?
Seamless Client Not Functioning
Re: Seamless Client Not Functioning
Have you generated a new connection client after the update ? You may also need to delete cache from previous client : http://www.terminalserviceplus.com/docs ... ted-client
