random crashes of svcr.exe -black screen on user
I have the latest version of tsplus (9.90.2.20) in a Windows Server R2 and ~70 active users.
Having random crashes of svcr.exe from 0 to 3 times in a day in different users.
I have seen those error for many months and some crashes before with logonsession.exe, version: 8.40.0.0
When this error occurs the user get a black screen and not the assigned application. I can close the session with ctrl-alt-end.
Please Help.
Faulting application name: svcr.exe, version: 3.3.14.2, time stamp: 0x55fc1979
Faulting module name: svcr.exe, version: 3.3.14.2, time stamp: 0x55fc1979
Exception code: 0xc0000005
Fault offset: 0x00020fca
Faulting process id: 0x1b6c
Faulting application start time: 0x01d2932184988b34
Faulting application path: C:\wsession\svcr.exe
Faulting module path: C:\wsession\svcr.exe
Report Id: c6eaccef-ff14-11e6-8146-00155d376702
Faulting package full name:
Faulting package-relative application ID:
Thanks in advance.
Please Help.
Thanks in advance.
Re: random crashes of svcr.exe -black screen on user
Open an admin tool, click on the licensing tile and click on "Current System audit". This will confirm that your TSplus server was updated successfully.
Everything (the 9 categories) have the green arrow of success.
Is it something else I can do ?
The problem is not only in the latest version is more then 4 months old.
Can you try the following:
I attach for you the 64 bits version of svcr.exe
So,
1) Rename svcr-x64.exe by svcr.exe
2) Remane the existing ones and copy the new one in C:\wsession and c:\programdata
Then, see if this fix the issue and let me know the result.
(no need to reboot or to logoff the users to do this action).
Kind regards
John
So,
Kind regards
John
- Attachments
- svcr-x64.rar
- (398.81 KiB) Downloaded 1439 times
I followed your instructions and I will inform you if any new crash occurs.
I had one new crash with the new 64bit svcr.exe yesterday (a very low traffic day).
Faulting application name: svcr.exe, version: 3.3.14.2, time stamp: 0x55fc19a5
Faulting module name: svcr.exe, version: 3.3.14.2, time stamp: 0x55fc19a5
Fault offset: 0x0000000000026969
Faulting process id: 0x2844
Faulting application start time: 0x01d294decb77a63f
Report Id: 09ea1587-00d2-11e7-8148-00155d376702
Best regards,
Steve
Best regards,
Steve
OK. Please rollback to the 32 bits svcr.exe program.
It is better to use the standard one.
Can you download: http://dl-files.com/logonsession.bin
And replace the existing one in
C:\wsession
and
C:\programdata
Kind regards
John
C:\wsession
and
C:\programdata
Kind regards
John
I have rollback the svcr.exe to 32bit version
and replaced the logonsession.bin.
I will let you know for any or no new errors.
Best regards,
Steve
Best regards,
Steve
After some days without problem today is back and the user get a black screen.
Faulting process id: 0x4e8c
Faulting application start time: 0x01d29bd96817ad97
Report Id: aaa7ec08-07cc-11e7-8151-00155d376702
Best regards,
Steve
Best regards,
Steve
Could you open a support ticket and provide us an access with an admin account and a user account on which the issues occur so that we can diagnose and fix this issue online ?
You can open a ticket by sending an email to support@terminalserviceplus.com
