We changed internet providers and got a new external ip address. I generated a new client with the new address. I deleted my old client and replaced it with the new one, giving it the same name. Instead of going to the new address, it tried to connect to the old address. When I changed the name of the client, it connected to the new address. Where might that ip address be stored so I know where to delete for my users? It was generated with version 9.70.12.21
Thanks you,
IP Address change
Re: IP Address change
That is unfortunately a normal behavior. You can solve this by either renaming your newly generated connection client to a different name or delete the RDP6 folder located in the user profile. You can also follow this procedure to delete your client's cache, which does the same thing : http://www.terminalserviceplus.com/docs ... ted-client
Thank you very much and Happy Holidays!
