I am trialing TSPlus at the moment and have noticed that for certain users their session doesn't disconnect when the application is shut down. The problem appears to be related to Windows 10 users.
For instance, each user logs in using the same login and password and runs an application using the web portal. They then close the application. The sessions for Windows 8.1 users are disconnected. The sessions for Windows 10 users remain indefinitely.
Can you look into this please and let me know if it is a problem. I am running the latest demo version of TSPlus.
Thanks,
John
Sessions not disconnecting
Re: Sessions not disconnecting
I believe that this issue has been fixed with the latest release.
I am running the latest demo version, downloaded last week, Administration Console version 9.60.11.8. Is there a later version?
