How many concurrent users on a 64 GB server ?
madmax
Post by madmax » Sun Sep 18, 2016 3:52 am
Hello
I'm testing TSplus and it's really amazing ! I read documentation and PowerPoint slide show available on TSplus demo server, and both sugests TSplus serves well 50 concurrent users, and documentation mention 16 GB server for 40+ users. I would like to know if I can support 200-250 concurrent users on a 64 GB server, given the estimated load for each session will be about 50-70 MB. The server will be 64 GB DDR3, 3x300GB SSD and 1 Gbps bandwidth running Windows Server 2012 R2.
hansen
Re: How many concurrent users on a 64 GB server ?
Post by hansen » Sun Sep 18, 2016 4:22 am
I would recommend you to split the users with the load balancer if possible. Just in case you got a problem with one server or just for regular updates/maintenance.
With that amount of resources, you should be able to run that amount of users. I've had 80 users running on a 32GB, which was sadly also running SQL and a couple of other things, which took about half the ram. Could easily run 100 users on that.
hansen
Post by hansen » Sun Sep 18, 2016 4:24 am
But it all comes down to your application and what load it puts on each user - CPU and RAM.
madmax
Post by madmax » Sun Sep 18, 2016 8:17 pm
Thanks for your replies
