New Release 9.50
Get the latest news, alerts & notices.
New Release 9.50
Post by admin » Tue Sep 13, 2016 10:09 am
- First publication of the release 9.50
This release includes all fixes made for the release 9.40
- It add one new feature
With the WebCredential GUI you can now set a maximum number of concurrent session "per user"
If you have a web enable application and you wish to have
3 users allowed for New-York
10 users allowed or Chicago
5 users allowed to Paris
And each user will connect using the WebCredential of his city this new feature enable you to manage such limit very easely
- It fix the issue of the system audit GUI
application settings.jpg (29.48 KiB) Viewed 26896 times
Re: New Release 9.50
Post by admin » Fri Sep 16, 2016 8:10 am
- First corrective release of 9.50
- Fix of the long logoff issue.
- Client Generator
Enable to display the user local taskbar even in "Full screen"
Fix of User Screen size
- Fix of File Select in web download
- HTML5:
1. When file transfer and sound are disabled at same time, this has disabled printer functionality too. Now I notice such case and force rdpdr channel forcibly (needed for printer functionality)
It is fixed now.
2. When you send many prints to fast, you can not open those in same frame at same time
To fix this kind of possible issue:, a delay of 1 second is set.
To increase this timing, it is possible to change in printer.bin
add %JOINDELAY(****ms)%
as example
PRINTERS=PS:%JOINDELAY(1500ms)%%PRINTHIDE%MS Publisher Imagesetter%Virtual Printer with Preview %; The timing is in milliseconds as example %JOINDELAY(1500ms)% would set it to 1.5 seconds.
This functionality affects only the Virtual Printers, not the Universal Printer.
3. New options has been added to settings.js.
W.disabledraganddrop = "no"; //by yes the files can not be uploaded by drag and drop anymore W.disableopenonclient = "no"; //by yes disable open on client via //tsclient/WebFile/openonclient/ W.disablechanneleval = "no"; //by yes disable JavaScript code execution sent from rdp session via Webime channel
Post by admin » Thu Sep 22, 2016 3:03 pm
A new version of TSplus is available.
- Long logoff issue: On some system the logoff was very long (over 3 minutes).
It is fixed now.
- The Client Generator was using default settings with low font resolutions.
As result, the character display can be blur.
It is fixed now.
- The smartsizing was mandatory when selecting the option to do not hide the
local taskbar. It is no more mandatory
- HTML5: enhancement of IE11 support
Post by admin » Fri Sep 23, 2016 8:21 am
A new version of TSplus is available, release : 9.50.9.22.
- There was an error pop-up when running a session without Full Desktop
It is fixed now
- The parameters of the Client Generator was not properly saved
It is fixed now
hanfelt
Post by hanfelt » Mon Nov 07, 2016 9:04 pm
Would be nice if you put up the changelog for 9.60 on the web and here at the forum.
hansen
Post by hansen » Tue Nov 08, 2016 4:46 am
This is from the email notification:
- For the first time over the past 10 years, TSplus is now managing the TIME ZONE REDIRECTION.
This is one makor enhancement for any customer in large country like USA, Canada, Russia, China or Brasil.
It is also very positive for any Cloud Computing hosted solution.
- The Floating Panel design has been improve and now the administrator has
amazing capabilities to change the background color, the button color...
- The filte transfer has been improve with better user interface
- The resize feature on HTML5 has been improved
- The modification of the screen saver in the Client Generator has been removed
- The 9.60 is including all fixes of the latest 9.50
- The feature to be able to use the TSplus shell opening preference has been disabled
on W8/W10/W2012/W2016
- The release 9.60 is including the latest development of the HTML5 client
hanfelt
Post by hanfelt » Tue Nov 08, 2016 8:17 am
Thanks alot i didnt know that i only clicked the changelog link in the update window and got redirected to a webpage where only 9.5 where published. Thank you for the information, have a nice day.
Post by admin » Tue Nov 08, 2016 8:28 am
I will post the release note later today.
