I have generated a local exe client on my desktop to access an executable application on the TSPlus server (version 9.20)
I want to pass some parameters to my executible from the desktop shortcut to control its function.
I do not want to hard code these paramters server side since I want to call my executable several times each with different parameters.
I can see that I can set TSPlus parameters on my desktop but how do I pass an actual parameter to the executable file?
Any help appreciated.
Cheers
David
Executable Parameters
Re: Executable Parameters
Generated connection client settings can be manually modified with this procedure : http://www.terminalserviceplus.com/docs ... ted-client
All connection client have their cache located in the RDP6 folder of the user profile. (C:\Users\name of the user\RD6)
It is however not possible to modify directly these settings in RDP6 folder as it is encrypted.
