TSPlus only allowing 1 login
AMHarris
Post by AMHarris » Fri Mar 25, 2016 10:50 am
Have TSPlus running 6.50 Printer Edition and it now only allows a single session when I have 5 license, I think the service has stopped and the servers normal RDP might me answering, what can I look for to confirm this diagnosticaly?
adrien
Re: TSPlus only allowing 1 login
Post by adrien » Fri Mar 25, 2016 3:09 pm
I advise you to update to our latest version using http://dl-files.com/UpdateRelease.exe
If the update program asks for an Update Code, please send us an email at support@terminalserviceplus.com
Updating will probbaly fix your issue, as our new versions are compatible with a lot more Windows updates.
As always, please backup your server before doing an update.
Adrien
TSplus CTO
