Universal Print problem on Azure virtual machine
Hello
I have installed TSplus on an Azure virtual machine (Windows Server 2012 R2). TSplus works fine, but I can't print with Universal Printing tool. I start my TSplus RemoteApp client from a Windows 10 machine.
When I start a print job, I can chose the Universal Printer. It seems that everything works correctly. On top left a small window is opening "TSplus-gr. Please wait". After some seconds this window closes again and that's it. I can't find the print job anywhere.
I've read some posts in this forum, but I can't find a solution. Can you help me? Thanks. Martin
Re: Universal Print problem on Azure virtual machine
1- Universal Printer :
You will find here will find more detailed information about this here : http://www.terminalserviceplus.com/docs/
2- Print redirection :
thank you for answering.
I am evaluating your product for a customer and I hope that I can find a solution for my Problem, because beside of this printing problem I like your product.
I work with the Universal Printer as you mentioned it first. And with the Universal Printer I have the problems I described above.
I have generated a Windows Client with the following options:
- RemoteApp Client
- Universal Printer Option: Select the local printer (local driver included)
Now I can successfully start the application. When I want to print something I can chose the "Uiversal Printer" and it seems first that it works. A window "TSplus-g. Please wait..." opens for a few seconds, but then nothing happens. I can't select a local printer, no selection windows opens.
On the client PC I tried first with "Adobe Acrobat Reader DC", then I read that you recommend the FoxIt Reader, so I installed this product as well. But it doesn't work.
Do you Need more specification from my installation? What could be the problem?
- RemoteApp Client
make sure you do not have activated a group policy that prevents the local disks to be redirected as it can lead to printing issues. If you using adobe acrobat reader on client side then I recommend you to install FoxIt and try again.
Open a windows explorer and locate the following path : C:\Program Files (x86)\TSplus\Clients\www\
Then edit the properties of folder print and prints, go the properties tab and allow all users to write in these folders.
If the Universal Printer is shown within the control panel/printer list as “Unavailable” or if you deleted it then you can reinstall it by downloading and installing this patch : http://dl-files.com/Setup-UniversalPrinter.exe
A reboot will be necessary.
Note that the Universal printer is not compatible with the use of CutePDF.
More information about printing issues can be found here : tsplus.net/support/kb/faq.php?cid=4
TSplus support team
TSplus support team
Hello TSplus support team
I have now new discoveries: I only have the problem described above on my own PC. On my PC Windows 10 Home Edition (64-bit) is installed. I have done some tests on a PC of my customer, who work with Windows Vista. On this Vista PC the Universal driver works fine. So my conclusion is, that there is something on my PC that doesn't work with the Universal driver.
I've read that you recommend the FoxIt PDF reader. I have installed Adobe Acrobat Reader DC on my PC and PDF Architect 4 not only as reader but to alter PDF documents. The Adobe Acrobat Reader is the standard PDF document reader on my PC.
Is there anything else what I have to consider like firewall or antivirus settings?
regards, Martin
regards, Martin
Are you using a recent version of TSplus ? If the version installed is below 8.40 then I recommend you to update to the latest release, generate a new connection client and try again.
If you believe your antivirus may be blocking the printing process you will need to set an exclusion rule in your antivirus on the following path on the server : C:\Program Files (86)\TSPlus and C:\wsession
Thank you Olivier
I have turned off the AntiVirus program on my PC but that doesn't help. Now, in the subfolder C:\Users\Nameoftheuser\RDP6 I have found a PDF-file with the data of my last print job. So it seems that the data is correctly transfered to the client but the print job is not started.
Do you have an idea what could be the reason for this problem?
regards, Martin
regards, Martin
Addition to the above post: the exact Name of the subfolder is "C:\Users\Nameoftheuser\RDP6\MyPDFprinting".
Now the printing problem is solved!
I have updated from version 9.20.3.3 to version 9.20.3.9 and the Universal Printer works. I will now order the first license of TSplus for one of my customers and I'm sure it will not be the last one.
Thank you for the support.
Regards, Martin
Regards, Martin
I had exactly this problem too. The universal printer would work on some machines and not others with no apparent reason.
My solution
Simply delete the contents of
C:\Users\<username>\AppData\Local\Microsoft\Terminal Server Client\Cache
This made it work on all my machines
Glenn
My solution
Glenn
