- This is the new 9.20 release!
- We added a new exciting capability to nearly automatically generate and install a certified SSL certificate. This is very important because many customers are expecting to use HTTPS. But... The process to purchase a SSL certificate, to turn it into a compatible one to install it properly is a long and complex process.
With this new feature, having a "green" HTTPS access is becoming as easy as starting Calc. It can be achieved within a minute AND IT IS FREE!
- The new Web Portal is now offering a selection of 20 different themes and changing the background picture is now very easy.
- The resize of the HTML5 session is now nice and very good.
- The UPN logon was not supported as expected.
For those who are not aware about UPN it is a logon using a email like string and this can be set in the Active Directory.
- Now using UPN or classical logon should not be a problem anymore.
- Some time the AppControl.ini file was blanked when started Assign Application or
- Add application, or Application from the start menu. This has been fixed.
- Most of the 9.10 issues has been fixed and this release is including all of these fixes.
New Release 9.20
New Release 9.20
Re: New Release 9.20
- RemoteApp fixes:
When using a generated client AND RemoteApp mode AND Select the local printer
the Universal Printer was not working. It is fixed now.
Same story for the Web Portal RemoteApp client
Changing the printer mode preferences (Preview, Select, or Default printer) was
not properly handled. It is fixed now
When the HTTP or HTTPS port number was changed, the file remoteapp2.js
was not properly updated. It is fixed now.
- The number of counted sessions was not the correct when zombie sessions were detected.
It is fixed now.
- RemoteApp fixes:
It is fixed now.
- Several minor bug fixed
- RemoteAppClient has now a completely clean uninstallation, and the clean.exe program as well as the "client.exe /clean" command line fully clean the "RemoteApp" folder
- RemoteAppClient Automatic Update : the progress bar now moves to reflect the actual download progression
- RemoteApp parameters files are now automatically cleaned every minute
- Reverse Proxy role: On some slow servers, some sessions was open on the Gateway
rather than on the targeted Application Server.
This is fixed.
- The Czech language has been added
- The HTML5 client has been improved for AutoCAD graphical display
- Some users had problem to connect with the RemoteApp client because
of a Windows issue on bit map cashing. We have set this parameter to 0.
Doing so, we are eliminating this issue.
Please note that most of our team is attending this week the TSplus International Meeting.
So our support react time can be slower than the usual one.
This is fixed.
- logonsession process has been change for better performances when one, or
mulitple applications are started at the session opening (no floating panel, no taskbar).
- The client generator have now 2 new options:
Low speed network (no background and no graphic animations)
Fast network (background display and graphic animations allowed)
- HTML5: fix to enable xhr polling connection on iOS
Improved SSL SNI recognizing for domain based forwarding
This is also ported on Java 8 for a better support of Java 8
Support of larger size for CTRL+C
- - This is the last release 9.20 before the announcement of the release 9.30
It already includes some nice enhancements
- The load balancing has been rewrite to support the "sticky sessions" feature
It means that a user will reconnect to the same server within a farm.
- The system audit has been rewritten
- On W10, we enforce the use of the Windows Shell to eliminate the issue
created after 10 minutes of idle.
- We added (on TSplus only) the new RDS Defender tools which is a shield
against hackers
- The HTML5 has been enhanced too
- The printing continue to work (web, generated client and remoteapp) even if
the user disconnect and reconnect his session
- The issue of application starting daughter processes has been fixed
It has also be tested when using a .bat file starting application.
- The logoff issue when publishing one application And the Windows Shell has
been fixed.
- The license activation in the AdminTool was including a bug which has been fixed
against hackers
been fixed.
