I am trying to understand how the File Transfer mechanism works when using the HTML5 Client. The Documentation say's:
"The sub-folder of gateway gets mounted as a WebFile device into your RDP session. Inside the RDP session you can access it via Explorer by clicking on "WebFile" or call "\\tsclient\WebFile" directly."
Does this mean ALL transferred files end up in the \\tsclient\webfile on the TSplus Server? Or does \\tsclient\webfile reside somewhere else?
Is it possible to change this File Transfer Location? e.g. specify a different location by Published Application or User?
Steven
HTML5 Client File Transfer
Re: HTML5 Client File Transfer
The HTML5 web client does not use \\tsclient for file transfer as disk redirection is not possible in this case. You will however be able to change your file transfer default folder in the admin tool / web tile / Web portal preference. Make sure the folder defined there is present on client and server side.
