Thousands of WebPrint Processes
dcipher
Post by dcipher » Mon Nov 16, 2015 9:29 pm
Does the most recent update announced Nov 16, 2015 fix the problem of 1000's of webprint.exe processes being created on the server? I have a windows 2012 server using TSPlus 8.40.11.6 which generates thousands of webprint processes for some users. In fact it creates them faster than I can "EndTask" in the Task Manager. The server is an iCore7 3.5 ghz with 4 cores and 16 gig of ram and the processor is running at 96% and the memory at 99% with only 12 users.
Simon
Re: Thousands of WebPrint Processes
Post by admin » Tue Nov 17, 2015 11:19 am
To eliminate this annoyance can you:
Download dl-files.com/webprint.exe
Unblock the file (right click properties and Unblock)
Replace the existing one on all of your servers (C:\Program Files (x86)\TSplus\UserDesktop\files)
This will be added very soon in the next update release.
dcipher
Post by dcipher » Tue Nov 17, 2015 9:50 pm
Thank-you that fixed the issue. The server is running properly today.
Simon
