i have a problem with the web login. When i log on the web service with an user which has only one application assigned, after few seconds there is a message with the subjet "fx" and something like "Application is still active. Quit before quiting windows." Then the session is terminated and i am loged out.
It takes only few seconds, so it is dificult to take a picture of the message.
Is there a resolution for this problem?
Thanks for help.
Fabian
HTML5 Web login - program close after login
Re: HTML5 Web login - program close after login
This means your application may not be suitable to be published as a unique application. Possibly because it require a full profile to be created first or because it got explorer.exe dependencies which is not an issue when a full remote desktop is launched.
I recommend you to first start with assigning the remote desktop or floating panel / remote taskbar. More information about this can be found here : terminalserviceplus.com/docs/remote-taskbar-and-floating-panel
