I have a question about keeping the administrator online and active. I have a few programs on a server that cannot run as a service.
Therefore they run under the administrator session. The administrator needs to be active all the time. What I want to do is
keep the administrator online but the normal users offline after a certain time of inactivity. In the TSPlus interface this
can be done easily, but when I set a parameter of i.e. 10 minutes, the administrator will be logged off as well after 10 minutes.
Anybody has a clue how to overcome this ? Thanks in advance for any help.
Best regards,
Aad
Keep administrator online and active.
Re: Keep administrator online and active.
Disable inactivity settings in the AdminTool, and follow this procedure to apply these strategies only to non administrator users : tsplus.net/support/kb/faq.php?id=19
The strategy you are looking for are located in : Computer configuration / Administrative template / Windows Components / Remote Desktop Services / Remote Desktop Session Host / Session timeout
Hi admin,
In your answer below you mention a link to tsplus.net/support/kb/faq.php?id=19.
This link isn't working anymore. Please, can you give me a new one.
Thanks.
Best regards,
Aad Gouka
Thanks.
Best regards,
Aad Gouka
Hello Olivier,
Thank you for your reply and link. I made a group Non administrators, started MMC and linked this group to a policy.
I installed the Session time outs and restarted the server.
This solution gives no result. The sign "Disconnected" on the Non administrator-user stays in the Taskmanager.
Maybe you have any hints to solve this.
Best regards,
Aad Gouka
Best regards,
Aad Gouka
Make sure that your administrator is not the member of user group, sometime a reboot is necessary so that changes take effect or use the command gpupdate /force in a command prompt.
The procedure I provided is for a server that is not a member of a domain. If your server is the member of a domain you will need to set these directly on your domain controller or allow local GPO to be executed, this is possible by activating this GPO on your domain controller :
