hi
I have 2 Tsplus servers in a common domain, and there is different applications on each server.
how can i publish apps from these servers and show all apps in applications portal ?
I want that : user just enters username and password and domain in web login page. then he can see all applications(that are published from server1 and server2).
I don't want user to select server1 or server2 in login page.(user don't now which server has which app).
thanks
publish applications from several servers in web app portal
Re: publish applications from several servers in web app por
Their is only one solution to implement what you are expecting.
With the Client Generator, generate connection clients which will start a connection on the target server and which will start the target application.
Then publish a set of such connection clients
The user will see the list of "application" assigned to him; when he will click on the icon, he will start a session to the right server and he expected application will run.
Kind regards
John Davies
Kind regards
John Davies
