RDP WONT WORK CORRECTLY AFTER TSPLUS 8 UNINSTALL
robmiles45
Post by robmiles45 » Thu Jun 11, 2015 1:07 pm
I recently uninstalled our copy of TSPLUS 8 from our Terminal Server. Since i have uninstalled it i am having problems with Microsoft Remote Desktop, it will only allow 2 clients to connect to the computer even though we have 25 cals. Before i had installed TSPLUS we had not problems but it seems this has changed some RDP settings and it causing us a major issue.
Any ideas or help would be much appreciated.
Rob
Re: RDP WONT WORK CORRECTLY AFTER TSPLUS 8 UNINSTALL
Post by admin » Thu Jun 11, 2015 1:11 pm
If your server had the terminal server installed before installing TSplus you will need to remove this role and install it again. You may also have to contact Microsoft if you encounter any issue your RDS cals.
