network printer redirection
Anybody know how to redirect network printer?
Re: network printer redirection
The best way to use a network printer from a remote location is to install it directly on the TSplus server, this way you will make it available for all of your remote users. However if you wish to use a network printer installed on client side within your TSplus session, the best way to achieve this is probably to use the Universal Printer.
You will find here a good tutorial on how to print using TSplus : tsplus.net/support/kb/faq.php?id=20
