Login Page Redirect
DamianS
Contact:
Login Page Redirect
Post by DamianS » Thu Dec 04, 2014 6:00 pm
Is there a way to have the login page redirect to the HTML5 session? Currently when a user logs in a new tab is opened with the remote session. I would like this to happen on the one page. Is this possible?
Damian C. Stalls
Senior IT Engineer
DamianS
Contact:
Re: Login Page Redirect
Post by DamianS » Thu Dec 04, 2014 6:13 pm
DOH!!!
terminalserviceplus.com/docs/web-logon-page-how-to-open-html5-client-in-same-tab
Damian C. Stalls
Senior IT Engineer
Post by admin » Tue Dec 16, 2014 2:01 pm
Haha glad you figured it out :D
Brian
Post by Brian » Tue Nov 03, 2015 8:30 pm
The common.js file has changed a bit. I'm looking to edit this so that all browsers open html5 in the same window. Any tips??
Here is what the current common.js file is:
p = hostGateway + 'software/html5.html';
if (cpwin != false) {
window.name = " " + k;
cpwin.name = k;
cpwin.location.replace(p);
} else {
var success = false;
if(window.open && window.navigator && navigator.userAgent && navigator.userAgent.match(" CriOS")) {
tmpwin = window.open(p, '_blank'); //Chrome needs _blank
tmpwin.name = k;
success = tmpwin;
} else if(window.open) {
success = window.open(p, k);
The old instructions above do not account for the 'success' part. I just don't want to change it per the instruction and run into problems :)
juwagn
Post by juwagn » Wed Nov 04, 2015 10:01 am
Evidently the code may change with time, have no idea why we have in our FAQ such code. Olivier could you please remove it from FAQ to not iritate peoples?
The asap solution.
In common.js locate
var cpwin = false;
and change to
var cpwin = window; //false;
At least for html5 that worked fine.
As I told, it is asap solution, since I have no real force to change things inside index.html/common.js, may be Adrien can add it as option, I have just no idea if he not yet did it.
