Open URL on client
mriffey
Open URL on client
Post by mriffey » Tue Dec 02, 2014 7:25 am
Where are the docs on this feature? I have looked all over the site, in the docs and in the forum and found nothing.
When the session opens, this URL opens: file:///C:/webtmp/3.14854877372272.html
Why is that? Where is this name coming from?
Thanks, Mark
mriffey
Re: Open URL on client
Post by mriffey » Tue Dec 02, 2014 9:20 pm
Solution from a user I know on Skype:
shellex to c:\wsession\urlonclient.exe maps.google.com/maps?
Please document these things.
jkuijt
Post by jkuijt » Wed Dec 03, 2014 7:15 am
Hi Mark,
They have just released version 7.80 with the following enhancement (and more):
Fixed URL on Client issue when it was not working. Also, no more tmp files copied on the user Desktop web using the Web Portal: please note that the Java client does not support this feature.
I see you often in the Clarion newsgroups. For which purpose do you use "URL on Client"?
Best regards
Jeffrey
mriffey
Post by mriffey » Wed Dec 03, 2014 7:34 am
Jeffrey,
Im attempting to use the URL on client feature to open a URL in their host system's browser (ie: not on the TSP server).
I am using 7.8, but this feature is not working and there is no documentation/diagnostic information that I have found so far.
Mark
jkuijt
Post by jkuijt » Wed Dec 03, 2014 7:42 am
Hi Mark,
Ok, then we have to wait for an official answer of Team TSplus. ;-)
BTW: Which client do you use? HTML5 Web Client?
Have you seen this link:
terminalserviceplus.com/docs/open-urls-on-client-side
Best regards
Jeffrey
mriffey
Post by mriffey » Sat Dec 06, 2014 2:16 am
Jeffrey,
Using html5 and generated client.
I got URL launch fixed - I had to turn off launch URLs on client (the function at the URL you posted) and use the syntax I got from Arnold. Go figure:)
Mark
jkuijt
Post by jkuijt » Sat Dec 06, 2014 3:11 pm
Hi Mark,
Good to hear it's working now. You want to share the special syntax of Arnold? I'm interested in it.
Best regards
Jeffrey
