I had windows 2003 server and everything was fine with TSPLUS. I actually have roaming profile on my doamin for some specific users. These roaming profile were working well with 2003, the TSPLUS was loading roaming profile properly.
Things changed with I used Windows 2008 R2 STD x64bit. TSPLUS is no more loading roaming profiles as each under windows logs into local only.
Please help.
Windows 2008 R2 roaming profile not working with TSPLUS
Re: Windows 2008 R2 roaming profile not working with TSPLUS
I cannot help you in that matter as roaming profile behavior tend to vary because each environment is specific. If your TSplus server is member of your domain than it should have inherited all domain strategies for roaming profile and folder redirection.
