Web Services not starting
Version 7.40.5.14 web serversives not starting. java was taking 100% of resources. I ended task and restarted server and not https and ssh tunneling will not start in tsplus... Please help.
Re: Web Services not starting
hello,
This issue can occur if you installed two different version of java on the server.
uninstall java and delete the java folder located in C:\Program Files x86\ then reinstall java 32 bits on the server and make sure antivirus or firewall software are not blocking HTML5service.exe and SSHtunnel.exe processes.
