I'm getting some errors when I connect to the server,
access denied this initial program cannot be started: c:\wsession\logonsession.exe
And other error related with universal printer
Please see the attached images
My server is windows 2008 R2 64 Bits
Logonsession error
Re: Logonsession error
It looks like there are securities set up on your server that prevent the user from launching a TSplus session properly. By default when installing TSplus on a server, all users have the NTFS rights to execute any TSplus program.
If your antivirus security is set on "paranoid" level than I recommend you to set up a scan exclusion on the following folder :
C:\Program Files (x86)\TSplus
C:\wsession
C:\wsession
