using with Chromebook
westonpf
Post by westonpf » Wed Apr 30, 2014 6:03 am
Which version of TSPLUS would I need to deploy applications to a browser on Chromebooks?
The trial version seems to do everything needed but I'm not sure if I need the HTML5 version that is used with mobile devices or the standard Web version.
Assistance in selecting the correct version would be appreciated.
Re: using with Chromebook
Post by admin » Fri May 02, 2014 3:20 pm
Chromebook or any thin client with a rdp client or a web browser is supported by TSplus. With a chromebook you will be able to open a remote session with HTML5.
