Problem with Mozilla and Chrome on your tablet
When you log in to TSplus by the Mozilla browser on the tablet I have only a blue screen. The application does not start.
By Chrome can not login but does not work to maximize and does not react to mouse cursor - a simulation of the left mouse button.
Works only with the default application "internet".
Tablet galaxy 7" 1024x600
tsplus 7.20.2.28
tsplus 7.20.2.28
Re: Problem with Mozilla and Chrome on your tablet
It is not possible to change the resolution of the html5 client.
However if you edit with notepad the html5.html file located in www folder you will be able to change the working area.
Default value
800 can be changed to 1024 or 1280 for example
Default value
watch file
..\Clients \ www \ software \ html5.html
and I do not see the specified variable.
Where exactly do I find?
I forgot to mention our online documentation once again
There it is :
docs.terminalserviceplus.com/html5-client-mobile-devices-resolution
There it is :
It does not work.
By default, I have set:
Code: Select all
<meta name="viewport" content="width=1024, maximum-scale=1.4" />
This issue has been fixed yesterday in a new release, please download and apply this update : http://tsplus.net/UpdateRelease.exe
It is still a problem.
Chrome already but you can maximize the window were leaving.
What Mozilla is still the same. Only a blue screen and mobile tools. No application.
image with tablet send ticket: 655976
Deleting internet temporary files and refreshing with control + F5 should do the trick.
Mozilla is still only a blue screen no application on the tablet.
Chrome is better, however, on the left side of the application is a black belt and not working clicking finger on the mouse.
Besides, it is a tablet so there's no such thing as Ctr+FN5
the " HTML page wrong version " message is also displayed after an update when the customer is using IIS rather than our built-in web server.
To fix it, you have to copy the entire folder C:\Program Files (x86)\TSplus\Clients\www\software into the existing IIS root path to replace the existing one.
