Problem seamless client
rpce
Post by rpce » Sat Feb 15, 2014 10:27 pm
The seamless client does not point out the option disks. I just do not want them to have the server installed. However, after logging in with windows 8 pro server client drives are mounted.
I tried the option Client.exe / clean but it does not help.
Even modified the client runtime parameters by adding the option "-disk off"
but it did not help.
How can I disable the client drives not edited for RDP?
Re: Problem seamless client
Post by admin » Tue Feb 18, 2014 1:38 pm
Hard drives redirection cannot be disabled because it would also prevent the Universal Printer from functioning properly. However you can hide the server drives using this procedure : tsplus.net/support/kb/faq.php?id=29
rpce
Post by rpce » Tue Feb 18, 2014 5:17 pm
I was about RDP client drives
Post by admin » Tue Feb 18, 2014 6:17 pm
it is the same for any Tsplus client.
rpce
Post by rpce » Tue Feb 18, 2014 7:58 pm
Interesting, however, is that if I use Microsoft's rdp client and drives off - seamless working properly;
