Hi!
I have set up Web Access under tsplus.net/support/kb/faq.php?id=41
Java and Windows clear the login/pass, but under html5 not cleard!
Help!
On Web Access Portal, is it posible to clear the user creden
Re: On Web Access Portal, is it posible to clear the user cr
Hi Barton
RTFM!
Please look at this article:
Best regards
Jeffrey
RTFM!
Best regards
Jeffrey
Sorry, didn't read your post that well.
Can you try with another browser ? We do need to work on that feature in the future to make it more reliable.
