The software development team is proud to announce the release of TSplus version 7.
This new major release is the cornerstone of TSplus 2014 roadmap and incorporates a wide range of new features and functionalities :
• Windows 8.0 and Windows 8.1 basic/core edition (32 and 64 bits) are now supported by TSplus.
• On W8/W2012/W2012 R2, we fixed the flickering/blinking issues caused by a poor Metro support of the Windows standard graphic driver.
• A new Web Portal design has been added for your users satisfaction.
• A new wizard where you can add applications has been created. It makes it very easy to publish applications.
• The TSplus service and the built-in web server services have been separated to enable a more consistent management of the web servers.
During 2014, we will continue to meet our customers expectations and we are pleased to inform you about some of the exciting upcoming roadmap's enhancements :
• We will add to TSplus Secure Web and TSplus Mobile Edition the advanced web credential security features that are currently offered only within TSplus Corporate Edition.
• The administrator will be free to create any kind of Web Portal credential (emails, pin codes with or without password) without using the Windows account credentials.
• The Web Master Toolkit will be enhanced to enable more Portal customization and options for users.
• We will create a Citrix-like Web Application Portal.
All our TSplus customers are invited to test the benefits of TSplus 7.10.
You can install a full trial version or apply the Update Release patch on your existing TSplus host(s).
For users upgrading from TSplus earlier release, the Update Release patch will keep the existing license and settings :
terminalserviceplus.com/download.php
TSplus Version 7 Major Release Announcement
Re: TSplus Version 7 Major Release Announcement
Here is the release note of all previous 6.xx version of TSplus in case you wish to know what's new !
- Attachments
[The extension pdf has been deactivated and can no longer be displayed.]
