hi
I cannot uninstall tsplus. I dont see any service on services list od server 2008r2
uninstall application hangs and never disappears
I have to uninstall this application immediatelly.
please help
URGENT - I cannot uninstall tsplus...
Re: URGENT - I cannot uninstall tsplus...
Follow these steps :
1- Open a control panel and manually uninstall the Universal printer.
2- Make sure no users are connected, then uninstall TSplus, reboot your computer.
If these steps did not work then download and install a fresh setup before restarting above procedure : dl-files.com/V6/Setup-TSplus.exe
I recommended you also to deactivate your antivirus before installing/uninstalling TSPlus
TSplus support team
TSplus support team
