Hi folks,
I could not succeeded to work with tray information. it seems printer universal driver only supports standard selection.
is that so ?
printer tray problem
Re: printer tray problem
In order to have more choice on how and where you want to print with the Universal Printer I recommend you to use the "preview as PDF" mode. Doing so a PDF will open on client side with your default pdf reader, you will then be able to print with your preferences.
