The HTML5 pages are not installed
sytze
Post by sytze » Sun Aug 18, 2013 9:25 pm
I am able to access my system fine with the Clients created, but I want to access the system via the Web. I tested this in my office and all was fine. Now I've taken the "server" to my client and am not able to log in via the Web.
I notice the system says The HTML5 pages are not installed on this system.
Is that the reason why I can't log in via the Web ?
I have googled to see how to install the pages, but I can't find a response
Can anyone here help me ?
Re: The HTML5 pages are not installed
Post by admin » Wed Aug 21, 2013 6:48 pm
Please download and install the html5.html file attached to this post and extract it to the following folder : C:\Program Files (x86)\TSplus\Clients\www\software
Restart the web services, your server should be fine.
TSplus support team
html5.rar
(8.43 KiB) Downloaded 1766 times
nvaughan
Post by nvaughan » Fri Jan 31, 2014 2:17 pm
I continue to receive "The HTML5 pages are not installed on this system". I have copied the file attached to this discussion, rebooted the server, and still receive the message. I am able to get to the logon page, but once I login I receive only a blue screen. I am running version 6.70.12.12. This was working earlier in the week, but I am having no luck now. Any suggestions?
jkuijt
Post by jkuijt » Fri Jan 31, 2014 3:49 pm
Yes, I had the same issue yesterday.
I upgraded from 6.80 to 7.20.1.29 and the file html5.html was NOT installed by the installer (only a .bak file).
After that I started the AdminTool and went to the "Web" section, then closed the AdminTool, and after that: the file html5.html was created!
Very strange! This never happened with previous updates.
So perhaps something wrong in the update installer?!
Best regards
Jeffrey
Barton
Post by Barton » Tue Feb 04, 2014 1:46 pm
I have windows server 2012 TSPlus version 7.20.1.31 and receive "The HTML5 pages are not installed on this system" File html5.html present. What to do?
jkuijt
Post by jkuijt » Tue Feb 04, 2014 2:08 pm
That's indeed very strange.
Perhaps you can run the AdminTool and change some settings under "Web"?
Perhaps that after that the HTML5 pages ARE installed?
And also try a reboot of your TSplus server. Who knows... ;-)
Best regards
Jeffrey
Barton
Post by Barton » Tue Feb 04, 2014 3:54 pm
I ran Admin TOOLS, rebooted the server, change the settings to adapt the portal anyway red cross. And the tablet can access the server by html 5. strangely
jkuijt
Post by jkuijt » Tue Feb 04, 2014 4:02 pm
Hmm, strange indeed.
Perhaps TSplus Support can advise further.
Best regards
Jeffrey
Barton
Post by Barton » Thu Feb 06, 2014 3:02 pm
Perhaps...
Barton
Post by Barton » Fri Feb 07, 2014 2:45 pm
Much easier!)
I changed the server name and activation fell off. Activated and everything was fine, include cleaning login password.
Thanks for all
