The version 6.10 Administration Console appears to hang when the HTTP/HTTPS Port Numbers dialog is opened.
It is impossible to close the dialog and the admin console stops responding.
Task Manager shows admintool.exe using 99% CPU. The only solution seems to be to kill the process.
Admin Console hangs when updating webserver ports
Re: Admin Console hangs when updating webserver ports
This only seems to happen on a machine which has been upgraded from an earlier version of TSPlus. The server had v3.5 (I think), which was uninstalled and v.6.10 installed. The configuration data appeared correctly in the new system, but this problem occurs.
There is no problem with a new installation on a system where no previous version has been installed.
In this case I recommend you to update your version of TSplus using this link : http://tsplus.net/UpdateRelease.exe
