Win8K
ept111
Win8K
Post by ept111 » Fri Apr 12, 2013 4:08 am
I have been using TSPlus on XO form years.
Recently I bought a win8 R2 server. I just installed TSPlus trial but it did not work.
Does TSPlus works as a Remote Desktop Services replacement?
Do i need to install or remove something on Win8 R2
Regards
ept111
Re: Win8K
Post by ept111 » Fri Apr 12, 2013 4:11 am
Sorry for my confusion I am talking about win2008 svr R2
ept111
Re: Win8K
Post by ept111 » Fri Apr 12, 2013 5:17 am
Update.
TSPlus was finally installed after that a Client was generated, but when I run it, it display a windows that says connection and hangs at the 25%.
The remote computer is running XP SP3
Any Ideas?
ept111
Re: Win8K
Post by ept111 » Fri Apr 12, 2013 5:30 am
The "connection window" appears after the "Preparing your desktop message"
Re: Win8K
Post by admin » Sun Apr 14, 2013 3:45 pm
This is a known bug and we are working on a solution right now. In the meantime I recommend you to extract the program attached to this post and replace the one located in the following folder :
C:\Program Files (x86)\TSplus\UserDesktop\files
You might need to rename the old one it first before replacing it and should not have to reboot your TSplus server.
TSplus support team
logonsession.rar
(585.91 KiB) Downloaded 1511 times
